Hi
I have had a new shed installed in the back garden about 3 meters away from the house. I want to install 2 double socket, light switch and florescent light fitting. I am planning to take a feed for the electrics from a socket in my back bedroom then run the cable (all in trunking) to an 13 amp fcu then run the cable up the wall to ceiling height and then through the wall to the outside and then hook the cable on to the wall with a wall anchor before it goes overhead into the top of the shed to feed 2 double sockets and the light switch for the light. Is a fixed 13 amp fcu the correct way or would it be better with a 13 amp rcd 30ma spur? Also what is the best way of attaching the cable to the outside wall, what are the wall anchors called for cable? I would only be using the power in the shed for a lawnmower, 12volt garden lights and the occasional power tool.
Stuart
Stuart
