wiring diagram to wire stat to vokera maxin 24e boiler
20 Oct 2009
Birmingham
Have a wireless salus RT300RF stat which I wish to fit to the above boiler. Connections on boiler are N,L,1,2 & 3(CONNECTION 1&2 LOOPED) and N,L,4,5,6,7(6&7 NOT USED).
CONNECTIONS ON STAT ARE 1) for 230v application SL(OFF),L,SL(ON) AND N.
2) volt free application NO,COM,NC,N AND L.
Any help grateful,Ad :) [/u]
your receiver will have a permanent live & neutral, these come from the mains/fuse spur or from the L/N on boiler.
you need to remove the link on 1 and 2 on the boiler
take a wire from terminal 1 on your boiler to the com terminal of your stat.
take a wire from terminal 2 on your boiler to N/O terminal on the stat
You will also have to remove the link in the receiver to make it volt free
Hope this helps
