wiring drayton rts5 to a worcester junior 28i
19 Feb 2007
Liverpool
Gotten a thermostat RTS5 for my boiler, (no existing thermostat)
Would be grateful for wiring advice -
boiler has -
neutral NS
Live LS
Switched live LR
RTS5 has -
N
L
1-COM
2-heating satisfied
3-Call for heat
I need to remove the link on the boiler and then -
Am i right by wiring the following? (boiler - thermostat)
neutral - N
Live - L + COM (linked)
switched live-call for heat
Any particular cable for the job?
3 core & earth 1mm???
yep already read that - i was just hoping someone with a bit of wiring knowledge could help me out.
thanks anyway.....
thanks anyway.....
sorry i appear to have no wiring knowledge then :?
im not sure what you are having difficulty with....its pretty clear what you need to do if you read the link or the instructions that came with the stat.
ok , so ive got 3 point on the boiler and 5 points on the thermostat - whats so clear about that!?
......and why cant all thes manufacturers just use the same names for the d*mn points!
Ignore the heat satisfied on stat, this is not req on your system
