My house had a Danfoss "RMT230 (with parallel accelerator)" fitted as a room stat to a metal back box.
The stat is supplied by a 3-core-and-earth cable with old colours : Red, Yellow, Blue and "Bare".
By inspecting the wiring arrangement of the RMT230 and by checking the Red and Yellow conductors I believe that the wires are as follows :
Yellow = Live (from timer/programmer)
Red = Switched Live (to wiring centre – CH On)
Blue = Neutral
Bare = Earth
I wanted to upgrade the CH control to a programmable wireless stat and I chose a Honeywell CMT927(BDR91).
I fitted the CMT927/BDR91 in place of the RMT230 and wired the BDR91 wireless receiver as below :
Blue → 'Electronics' Terminal 'N'
Yellow → 'Electronics' Terminal 'L'
Red → 'Heating' Terminal 'B'
Earth → Back Box only
+ Short length of conductor connecting Terminals 'L' and 'A'
The new stat appears to function perfectly correctly and I can find no 'problems' except in one regard : I recently discovered that after switching on the whole system from scratch, the Diverter Valve gradually heats up to a temperature which seems excessive (very hot to touch) and does not appear to cool down even when there is no 'active' CH in progress, eg even overnight when the stat temp is set so low as to be 'off'.
It's as if the motor in the valve is 'working' even though the call for heat is absent.
Can anyone suggest a cause for this ? Have I wired up the CMT927 correctly ? Can the Diverter Valve remain 'very hot to touch' even when there is no call on CH and no call on HW ?
Blue = Neutral
Bare = Earth
