Wiring lighting problem in garage
11 Dec 2009
Tyne and Wear
Tried to replace a dim bulb with fluorescenttube in the garage and something has gone wrong as follows:
There was/is a 3 core supply direct to the light and off that a 3 core cable to a stand alone switch.
With everything wired up the light comes on automatically. When the switch is touched (on or off) the whole circuit trips.
Obviously I have done something wrong with the wiring set up as when it was just a bulb the switch/feed worked ok.
Any help gratefully appreciated.
The two lives/neutral/earths are all connected via junction boxes to the feeds into the tube housing. I guess this is where I am going wrong.
Adrianne
So what do i do?
I have a neutral from the main feed to the light going into a connection box with the neutral running to the light itself and the other neutral from the switch is also connected to this.
Do I just disconnect the neutral from the switch?
Thanks upfront
Adrianne
So what do i do?
Learn how lighting circuits work.
not all of the black or blue conductors are neutrals, the one from the switch will be the switched live.
It's not a neutral, it's the switched live. It's because you have connected it to a neutral that the MCB is tripping.
http://www.diynot.com/wiki/electrics:lighting
The red to the light should go to an empty terminal(there should be 4 terminals) then connect the red from the switch to this terminal, the black from the switch should have a red marker fitted(pvc tape will do at a pinch) then connected to the terminal with the internal red or brown wire.
