wiring one gang switch
8 Nov 2005
im not sure how to wire this switch. ive run a cable from a fused box in my shed to a switch and then a cable to a 60watt light. i will have 2 :o cables at the switch how should i wire it
How do you suddenly get from two cables ("a cable from a fused box in my shed to a switch and then a cable to a 60watt light") to six cables?
i have the cable coming from the light to the switch and a cable coming from the fused box to the switch
hope this makes sense
how would i wire a 2 way switch
is this possible
ty :?
BAN i think he must mean 'wires'.
Join the two earth (bare) wires together once sleeved with green/yellow sleeving either to the earth terminal on the switch box or if it is plastic a terminal block. Join the two neutral wires (black or blue) together in a terminal block and connect the live wires (red or brown) through the switch com and L1 terminals.
many thanks
this is what i though but just wanted to be sure
would this be the same with a two way switch as "our lass" has just informed me she has bought a two way switch instead of a one way
many thanks for the replies :)
But now he wants a 2-way switch... :?
Brewman - how big is this shed? Why do you need 2-way switching?
BAN he said he has bought a two way switch not that he needs two way switching!
With a two way switch you just use the common and one of the L1/L2 terminals. Which one you use will determine which way the switch is up for on/off.
Once again thank you for you advice
Keep up the great work
:D
