Softus said:
cold storage cistern (which is not a tank)
Some definitions off the Net:
Cistern - A fixed container for holding water at atmospheric pressure, normally applied to the local water storage to flush a WC. It is normally fitted with a float operated valve and overflow pipe.
Cold water storage tank - A fixed container for holding water at atmospheric pressure usually used for providing a feed to domestic cold water and/or to a vented domestic hotwater system.
Hot water cylinder - A closed vessel (normally cylindrical) used to store heated water under pressure greater than atmospheric.
Indirect hot water cylinder - A hot water cylinder where the water heated by the boiler is fed through a coil of piping inside the cylinder to heat the domestic water. The
tank (
sic)often incorporates an electric immersion heater so that the tank (
sic) can be heated when the boiler is switched off for the Summer.
You say "tomarto" I say "tomayto" .Take your pick
when it is done then the cold storage cistern (which is not a tank) must be raised such that level of water at peak demand doesn't drop below the height of the top of the pipe that draws water from the top of the cylinder.
Technically correct. I was just trying to point out, in laymans terms, that the tank/cistern which does the feeding has (in general terms) to be higher than the cylinder/tank being fed.
The hot water pressure in an open-vented system is determined by the difference in height between the water level in the CSS and whichever outlet is being used.
I must remember to read through what I have written before I post it
