Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
To return to topic, your point about cable with a 20A Iz being acceptable for a 32 ring final is a good one and, as you imply, suggests that '20A' JBs should be OK in such a circuit. Indeed, I doubt you'd be able to get anyone to say that the terminals of other accessories (particularly sockets and FCUs) commonly wired into rings are 'rated' at 32A, although I'm sure that most are 'fit for purpose'.
Personally, flak or not, I take the 'current ratings' of JBs with a large pinch of salt. What matters to me is the conductor accommodating capacity (as judged by me, not by what's written on the JB) of the JB terminals. I've seen plenty of cheapo '30A JBs' in which I would not attempt to terminate, say, 3 x 2.5mm² cables, yet some better quality '20A' ones which would be fine for that job!
Definitely. Some of the worst 30A types can be a real squeeze just to connect two 4 sq. mm conductors together in one terminal without some careful "packing" down of the strands first.
