Electric feed to shed
10 Dec 2008
Cheshire
I have demolished my old garden shed and replaced it with a new one.
The old shed had an electric feed from the house. The cable is fed underground in a sleeve for protection and is plugged into one of the undercupboard wall sockets in the utility.
The whole house is protected by rcb's.
My question is how should i terminate the feed in the new shed. should i provide another rcb, a fused spur or purely a junction box.
The shed feed will be for;-
Electric light
Socket for mower etc
Feeder cable for pond pump (switched)
In my opinion, if you intend to do anything properlike, then this should be installed by an electrician. Thus I'd keep it as it is - a permanently plugged in extention lead.
Never really thought about it as a plugged in extension. Thats basically what was there before. I was just thinking it should be something better.
For what you're going to use it for, it doesn't sound like it's worth the bother to be honest although i suppose you could replace the current 13A plug with an RCD one
Unless you fit a 10ma RCD then no point in fitting a second
Electric light
I would feed into three socket boxes connected with tube nuts one with socket and two with switched fused spurs one for light other for pond.
Really speaking the cable should be SWA but once you start to up-grade rather than like for like I am uncertain how the Part P rules work?
Note:- If permanent fixed it can still come under Part P even if plugged in.
