I would keep them in separate channels. If ever the gas pipe has to be repaired then the cable will be in the way, and same goes for future replacement of the cable.
I expect someone will be able to advise better than I can but with regard to what I said 528-02-04 works for me
"Where a wiring system is to be installed in proximity to a non electrical service it shall be so arranged that any forseeable operation carried out on either service will not cause damage to the other"
