    Dismiss Notice
Wobbly Franke Olympus Tap
Discussion in 'Plumbing and Central Heating' started by TimperleyCH, 1 Nov 2011.
  1. TimperleyCH
    TimperleyCH
    10 Feb 2011
    10
    Thanks Received:
    Cheshire
    Country:
    We've just had a kitchen fitted, with a Franke Olympus tap (http://www.frankeonline.co.uk/olympus-338-p.asp) into a granite worktop.
    The base of the tap is really solid in the worktop.
    However, the swiveling spout of the tap is far more wobbly than I expected. There's several mm of play. Enough to make me hold the tap gingerly when I want to rotate it.
    I've removed the spout, checked the o-rings and checked the grub screw seats into the slot in the plastic washer. But it still wobbles.
    Please does anyone have any comments on if this is this normal?
    Thanks.
  2. Sponsored Links
  3. HERTS P&D
    HERTS P&D
    9 Apr 2010
    12,532
    Thanks Received:
    1,916
    Hertfordshire
    Country:
    Does it leak from the body to the spout?
    Andy
  4. TimperleyCH
    TimperleyCH
    10 Feb 2011
    10
    Thanks Received:
    Cheshire
    Country:
    No, I can't see any water leaking from the base of the spout. So I think the o-rings are sealing things as expected.
    Thanks.
    Andrew.
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
