Please could someone help me,i have the above boiler the ch works fine but there is no hot water.Ive been told i need a new diaphragm in the divertor valve,however if i run the hot tap slowly the valve does not press the micro switch.If i run the hot tap hard enough it does press the micro switch and the boiler fires up but still no hot water,if i run the hot tap slowly and press the micro switch manually theres still no hot water.If the ch has been on i get hot water for about 10 secs or so.Ive seen a 24 cdi manual that suggests maybe the hot water sensor,the hot water thermistor or even the gas flow valve are to blame,also there are no flashing fault lights on the front panel all lights work ok.would be really gratefull for any helpful info thanks.
