Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I have an old style Worcester 24i boiler installed. My red needle on the pressure guage is set to about 1 1/2 however the actual pressure needle usually runs at around 3 . Does anybody know if this is right, and if not how do I reduce the pressure in the system
PANIC ITS ABOUT TO BLOW!!!!!!!!!
the pressure should normally reside around 1bar when cold to a max of 2 when rads are hot. check if the filling loop has been left open . then reduce the pressure from the drain off under the boiler or at a rad bleed nipple
The filling valve isn't open, how does it keep increasing, is that a fault, also where can I drain it and is it essential I do it as you can tell, I havn't a clue about boilers..
Does the pressure read normal when cold? 1-1.5 bar. Then go up to 3 when on? Does water flow out the p.r.v outside? If all these are true it sounds like an expansion vessel problem. Might just need pumping up, or split membrane.
If you get the feeling of chasing your tail with the pressure vessel thing its time to look into the possibilty of an internal leak in the secondary heat exchanger
Thanks for the advice everyone, I think I will call an engineer out, I am about as technical as a broken ruler... I had a look last night and the pressure went to 3 1/2 when everything was off, it seems to go down when the heating is on, but up when everything is off..
