worcester 24i rsf-cant bleed
3 Feb 2011
Essex
i replaced the prv as it was letting by, recharged the pressure to 1.5, and turned back on, after 20-30 seconds i could hear "gurgling" then a dull knocking, sounds like air in system, bled all rads(all fine)took cap off pumphead and that was turning ok. noise does stop when i turn on hot tap but returns a few seconds after turning off. its an old boiler and does not have(that i can see) the auto air vent,though it does have a small tube sticking out the top next to the reset button with a "washing up liquid bottle top" cap. any suggestions are v welcome
Apart from the noise, is it firing up and giving hot water and heating?
Tony
fires up first time, good heat but reluctent to leave on too long as it starts to make quite a rattle, thanks
forgot to say needle on the pressure dial bounces around. but does not gain/loose when off.
