Hi All,
I've the Worcester Combi which sometimes locks out and won't fire. The vent fan will be running. If you disconnect the negative pipe off the pressure switch it will "click" , reset and the boiler will fire. It normally happens on start-up after an "off" time period of the programmer but tonight happened whilst delivering hot water.
I changed the original pressure switch with a 0.9 mb Honeywell (used but serviceable) a couple of weeks ago which ran well until tonight. The switch pipes are clear with no apparent leaks.
I have now changed the used Honeywell tonight with a brand new unit,1.0 mb but knowing my luck the problem will arise again.
Any help would be gratefully accepted.
