Worcester 24i wireless thermostat and programmer
28 Sep 2012
Hi all,
I am planning on installing a wireless thermostat and 7 day programmer onto my Worcester 24i. Whilst looking in the wiringing diagram it shows room thermostat connection and a programmer connection not a single connection that does both! Do I need to connect it to the the room thermostat connection or do I need to get 2 separate controls? One a thermostat and the other a programmer?
Having just gone and had a look at the oiled oiler it's got a manual control attached to the mains programmer and a frost thermostat to the thermostat connection (as my boiler is in a external service room) should I disconnect both and then simply attach the wireless receiver to the rooms thermostat and then just put a link in on the mains programmer
Please help
Adam :D
You can use a programmable stat and wire it as in the programmer option as follows:
Receiver -- Boiler
L ------------ Ls
N ------------ Ns
3 ------------ Lr
2 -- Link to Receiver L
What does the manual control do? Can you post a pic of it?
The frost stat should override the programmer and wall stat and turn the boiler on when the temperature drops below the stat setting.
