Had the heat exchanger out to clean it unfortunately I thought I twisted the off valve to the mains water of the boiler and I hadn't. So it sprayed water all over the boiler for a moment.
I have replaced the exchanger with no leaks, although now I left the boiler to dry for a while and when it fires up it ignites but the light for the FLAME symbol isn't coming on for either hot water or central heating.
Before I call someone out to service it (it needs it anyway) and get him to fix whatever the issue is I just wanted to know if it is something simple.
I was told it may be that the PCB is still wet or water is on a connector making the system lock out. Or Water has gone on the gas valve meaning I need a new valve. Or the third suggestion was that because all valves where shut off you may have an air pocket in the gas valve causing it to cut out.
