worcester 28i boiler - increasing pressure
31 Dec 2008
Edinburgh
After bleeding the radiators, the gauge now shows at almost zero (with the radiators off). How can I increase this to the manufacturers recommended 1.5 - 2
There is a silver hose which links the domestic input and central heating return pipes. (picture included)
Any help would be greatly appreciated.
Here are the pics in the following links -
You will need a small pair of grips or pliers as the handles have been removed from the valves.
first open the one on the right a quater of a turn, now open the one to the left slowly, you should be able to here water running. allow the black needle to read a little over one bar. close off both valves.
One side of the loop should be disconnected on completion.
thanks this is very helpful
I have managed to open both values, I cant hear water running through, however water is coming out from the right hand valve. The pressure is still not rising. Should this take some time or only a minute or two?
Also should the boiler be on or off?
thank you thank you for your kindness and explanation
On closer inspection I was just turning just the screw not the whole valve. It seems fine now
Thank you very much
