hi,
i have a combi as stated , can anyone tell me where the 2 black wires from the boiler go to on the flex plate. may sound like a stupid question but they pulled out accidently, thanks.
hi londonboy,
from the boiler their are 5 wires, blue,brown,green/yellow and 2 black wires. these pass through a plate which has a connector block on back, the blue and brown then go to a fused switch plate and the earth connects to the rear off the holed plate. the thermostat wires also connect to the rear of the holed plate. the black wires should also fit there but where? hope you can understand this, thanks.
