Hi, Hope someone can help,
I have a worcester 28i rsh combi boiler, about 5 years old,
Got up one morning about 2 weeks ago, had no c/h, the pressure gauge was at 0, let in water and bought up to 1bar, (done this a few times over the past 4 years)
This time nothing happened, turned off the boiler for about 10min,
turned the boiler back on, it made all the normal noises (a couple of clicking noises and pump starting) but no ignition,
turned on a hot water tap, everything worked fine on the hot water side.
If I leave the hot tap on for about 15 minutes then turn it off, the c/h will stay on???
The pressure gauge will increase to almost 3bar, the boiler will then shut down, it will start up again when the pressure drops back to around 1bar,
after this happens a couple of times, the boiler shuts off after reaching 3bar, but drops back below 1bar and will not restart, the pressure will
slowly drop back to 0.
If you monitor the pressure and keep refiling when you see it drop a little the boiler will continue to work.
I was told it may be a faulty prv, I have changed the prv (no difference)
Help
[/b]
Help
[/b]
