worcester 28i
17 Dec 2005
Cheshire
Love the site and banter read more posts then i type just refitted boiler after 4 months building work fan replaced but wont fire up after 2hours found boiler works without restricter ring boiler 4years old will this cause any damage
Check if cap on flue sampling point is missing - on top of boiler.
Leaving out restrictor ring will reduce boiler efficiency and may cause lockouts. I assume flue lenght hasn't changed.
Sounds like there's still a problem involving the fan and pressures inside the boiler. If it works without the restrictor, this implies that the airswitch is responding to slightly lower pressure from the venturi (oops - can't remember whether there is one on this boiler: anyway, not relevant. Take out ring - internal pressure lower).
Are you absolutely sure there's no inward leakage past the case seals?
