Worcester 30cdi problem
29 May 2014
Middlesex
Hi
I have an issue with worcester greenstar 30cdi.
No lights on front panel but when I press power button I hear pump turn on and off.
If I turn off I get drips from bottom of boiler.
Pressure is low but if I top up it leaks straight out of bottom.
No fault codes. Reset button does nothing.
Any ideas
Also front panel of boiler feels hot, sure it doesn't normally.
And it's just tripped all the power out
Best to get gas reg engineer in. Could be water damaged and blown a fuse
Switch off and leave till an engineer take a look.
Daniel.
Sounds like its cracked a plastic part.
Check the installation date and warranty cover.
Otherwise call an RGI to check it out.
Make sure you leave power to it off to minimise the damage to the electrical parts.
Tony Glazier
Definitely get it checked by a gas dude but sounds like a loose joint on the pipe manifold where all the key pipes connect to or maybe even someone left the fill key in unlocked ?
Dripping water isn't good, there is mains electric on the panel so personally I would get it checked ASAP and isolate the mains.
