Worcester 4000 termostat
5 Sep 2023
Hi
I just installed a Worcester 4000 and I put easycontro ct200 as the termostat. And this is wireless but is not working so don’t know what to do. The heating is turning on all the time if the radiator temperature is set to high and will not stop at all. I think I put the wires wron on the pannel. I will attach photo so you can have a look.
That’s not the best wiring, and can’t see what it’s joined to. Also unless you’re gas safe registered, shouldn’t be opening the cover on your boiler.
There is the power supply wires and them two that go across everything are the power supply for the termostat. From what I know on this termostat you need to connect only the power supply as everything else is wireless with the key. I find a diagram online for this boiler but not helpful. Only thing I did is to connect the power sufor the terostat
