I've noticed my boiler (Worcester 40CDi condensing natural gas) is cycling a lot of the time. It's the usual (usual because Google is full of these complaints) getting up to around 40-50 and then switching off with the thermal cut-out symbol.
Sometimes its OK, but most of the time it isn't.
The pump is recently changed so I'm confident it's not that. I suspect it's the flow from/to the boiler and the heated water therefore can't get away quick enough, thus boiler switches off.
Last night I tired turning on the CH value and - hey presto - the boiler liked that and all worked OK. Apart from a really hot house! The HWC heated up within 20 mins as usual.
So (you guess, I'm not a plumber) I'm inclined to think there is an issue with the HW circuit. It's an S-plan system. The pipework is 22mm plastic, apart from near the boiler. The HWC is about 6 or 7 years old, so my suspects thus far are:
- HW motorised valve no opening enough, restricting flow when the CH is off
- HWC clogged up with crap (i.e. the copper within it not allowing enough flow
- Plastic pipe to/from boiler clogged up with crap, again restricting flow
Am I on the right track?
