Hello everyone me again. This time a combi as mentioned in the title.
The fault is when heating is turned on it runs for 10 minutes and then turns off the house hasnt warmed up yet pressure rises to 1.8 bar.
After looking at a few things i checked the expansion vessel it had very little air in and when the valve was pressed water came out which tells me the diaphram inside has perished.
It removed the tank full of water and drained it bits of rubber came out!
I got a replacement tank but it didnt fit in so am waiting for a replacement.
I reinstalled the vessel as DHW is needed but when the demand is made pressure jumps from 1 bar to just over 2 then thermal cutout happens and pump runs for a while trying to dissapate the heat.
Am i on the right track by changing the vessel?
