Hi
I had a 28i boiler fitted to my old heating system last year... A few months ago started redectorating and removed a few radiators. I turned the boiler off, and a few months later after a holiday and finally getting things put back together I filled the system and turned the boiler back on last week.
I've bled all the air out of the system, but now when the heating is running the system locks out and goes to a light sequence I've identified from the manual as 'ignition lockout'.
If I run the hot water, this works fine and the boiler stays running as long as the hot water runs.
If I stop, it will re-light (the green light goes on/off) a few times then lock out again.
The manual suggests checking the flue - I'm not sure what to check (though I have checked no birds have nested whilst it's been off!) but all looks fine, and I can't see why it would work for the hot water only.
Any ideas?
Any ideas?
