Hi all,
my recently installed boiler; less than a year old, has started making a vibrating/buzzing noise, it lasts between 3 to 10-15 sec then stops, there are no errors showing on the display. I can also hear a slight water trickle sound if I put my ear to the case.
Ok History, I had this installed almost a year ago, and in the first few weeks I discovered one of the rads had a leak, and the bedroom rad made constant trickle noises, I contacted the installer who promptly ignored my call and txt.
I have moderate technical knowledge so I sorted the leaking rad myself; this damaged the carpet; small rust spot from the drips and blew my paint from the skirting - i.e. it peeled off in a sheet. The other issue I have not been able to rectify even though I have bled the rad.
Oh forgot to add I have those vertical rads like these: Vertical Radiators
