Worcester Bosch HE 30/35
If you're any good with a multi-meter you can check the sensor on the hot water pipe to see if it is working correctly.
Its a quick and easy test to check it and if the sensor is broke, they are pretty inexpensive to replace
Hello, gas is on full, I can run a bath that is hot but not as hot as it used to be. Tonight I made sure the CH wasn't on and it still wasn't as hot as it used to be. I did notice after I ran the bath I closed the tap for a while and opened it again, there was a little hot water but it went cool again after 10 or so seconds.
