Hi
I've recently encountered a problem with my Worcester Bosch Highflow 400RSF boiler in that I can only get a tepid shower. The basin hot taps are generally ok (I must check the bath taps separately) but it seems that the boiler isn't able to keep up with the demand for high-flow hot water like the shower.
The boiler has tripped out (overheat) a couple of times too lately. It was serviced and this was mentioned, but the engineer replaced only the expansion vessel.
Shower water temperature was okay before the expansion vessel was replaced. The expansion vessel had leaked and was full of water. This was replaced a couple of days ago and since then we've had tepid showers. The boiler has also cutout (overheat) once more since then too.
It may be coincidence, but I'm thinking one of:
1) Diverter valve failed
2) Sludge/restriction in the CH circuit causing diverter valve to stick
3) Water-water heat exchanger
4) Shower cartridge (Triton Sentiment thermostatic mixer)
Rather than replace everything, can anyone offer any advice as to how I might narrow down the problem? Or, if I'm completely wrong, has anyone else got any other ideas?
Thanks in advance
Thanks in advance
