have a problem with a recently fitted worcester classic combi with new pipework and rads .
thought I might have a leak as the pressure was dropping so I have checked all pipes and found no leaks .
I have bled all rads and set the pressure again which started to fall slightly over two days , when hot water is running it drops then when you stop running hot it goes back up to where I set it to then drops again after a while
My question is why does running hot water affect the pressure in the heating pipework when the heating is off ?
