Recently I've noticed that when I turn the hot tap off the boiler will either continue running or the boiler comes back on shortly after, it fires up and you can hear the pump running even if I switch the boiler to off, the only way to stop it is to turn off at the spur.
The Honeywell digital stat does not show a flame indicating its running and is set to manual at a very low heat to stop the boiler working.
Any ideas what would cause this?
