We've recently installed new pipework and fitted 4 new radiators as well as pipework for 2 towel rails yet to be fitted. After pumping the system to 2 bar there is a rapid decrease to 1 bar or less. We've partially bled the radiators (still air trapped in the system - it's taking time to bleed) and checked all pipe fittings. There doesn't appear to be any leaks on the pipework or radiator valves. What could be the problem? The gas fitter says that symptoms indicate an open pipe and that it is not a problem with the boiler. However the plumber suggests it might be the schrader valve. There has been no service or valve test of the combi.
