Worcester Comfort+II losing RF connection
1 Oct 2025
I've a Worcester Comfort+II thermostat which connects to the Greenstar boiler via a "Key" receiver unit inserted into a slot in the boiler
The system is three years old, and has been completely fine, but has in the past few days started losing the RF connection
Following instructions from the user guide and online searches, I've:
- replaced the batteries in the thermostat with new ones
- removed the batteries from the thermostat, waited 10 minutes, and re-inserted them
- factory reset the thermostat
- factory reset the key
- moved the thermostat to within 20cm of the key, with a direct line of sight
- unpaired and re-paired the thermostat and key from the installer menu on the thermostat
Each time, it seems to work fine, the LED on the key goes from flashing yellow (pairing) to solid green (paired) and the controls on the thermostat can then be used to switch the functions of the boiler on and off correctly
But, then, a few hours later, the connection is lost, and the message ("No RF signal") appears on the thermostat again
Anyone have any idea what's wrong?
Out of curiosity, what batteries are you using, Zinc or good quality Alkaline?
I'm using good quality alkaline
RF interference: possibly. There's no pattern with anything I'm using, but we live in a flat so could be the neighbours, not sure what I could do about it?
Try moving the thermostat nearer to the boiler and see if that makes any difference?
I would just do the obligatory Copilot AI search, go to:
and paste in:
"Why is my Worcester Comfort+II thermostat losing connection after a few hours, and the message ("No RF signal") appearing?"
and check you've done what it says there, which I think you have.
If moving the thermostat nearer doesn't do anything, it's going to be a hard problem to troubleshoot, and may be a faulty RF module, so I would talk to Worcester support.
