Worcester greenstar 24i blank display
28 Nov 2008
Dorset
Hi
I have a Worcester Greenstar 24i gas boiler. Its about 3 years old and regularily serviced.
Recently the front panel display went blank.
The boiler still works fine and can be controlled successfully using the room thermostat.
I have checked the three fuses on the control board and they are all fine.
The only other thing that I can add is that the problem occurred not long after the boiler was serviced. However I dont think that the service caused the problem.
What could be the fault? What might be the solution e.g. is it likely to be the PCB board that would need replacing or could it be any number of possible causes.
Thanks for any help
