Worcester greenstar 4000
23 Sep 2022
Hi, so I had this boiler fitted yesterday, now there seems to be a couple of problems with it.
When I turn off the cold tap I get a big whooshing noise like water is rushing into the boiler, I've tried turning all the taps on to see if I can get an air bubble out and nothing.
Also one of my radiators only seems to go hot if I turn the other ones down, is this something that will settle in time?
Thank you for any help.
First port of call is to contact your installer as mentioned above. Pointless scratching your head until they have looked at the issue.
Was it a like for like install or converted from a hot water cylinder? Also does the boiler fire up when you close the cold tap?
Yes it was a like for like, and yes was firing up when close the cold tape, just the one in the kitchen though, but we have manage to sort that. Thank you
