Hello,
Hope that somebody can help. My brother has just fitted a brand new Greenstar gas combi. The electrician had removed the factory fitted bridge wire on the control board and connected up the thermostat. Unfortunately he had caused a short circuit and it blew the 2.5A fuse on the control board. when it was pwered up.The bridge was refitted and a new fuse fitted but the central heating will only operate if the maintenace button is pressed. DHW is not affected and works normally. My fear is that the PCB may be damaged but I'm not really sure. The boiler was just given a short run to check it's operation prior to a corgi plumber carrying out final commissioning.
Cheers
Cheers
