Worcester Heatslave. No lockout, no spark.
7 Mar 2016
It's a 15/19. Stopped heating. The fan kicks in on the boiler, but there is no spark, at least nothing I can see through the hole if I pull the photocell. I would expect it to be locking out, but it doesn't. I'll have a look at the wiring diagram, but does the lack of lockout suggest the Satronic control box is getting things wrong?
If you pull the photocell from its socket, keep it in absolute darkness while you try to start up......if it does start, show the photocell a bright light immediately.
Maybe a better test is to pull the burner from the boiler, disconnect the solenoid coil from the oil pump and you should see a spark across the electrodes.
John :)
I'll reply to my own question. Yes it is the control box. The lockout button has been slightly melted by whatever has burned out inside it.
