worcester junior pump head replacemenet query/isolation valv
3 Jan 2011
Hertfordshire
The pump has been blowing the 3 amp fuse in the fused spur - so have ordered one up to replace (pump head)
basically, my question is - is it best to drain down whole system or to just isolate boiler flow and return valves under boiler and drain down boiler? I am wary that these can leak when re-opened !
Any tips for draining down a boiler to replace a wet part would be helpful
Thanks for reading
Just drain it.
If you use the iso valves you will end up draining down to replace them.
ok thanks for helping
drain the whole system until it stops then i guess and refill with inhibitor the best bet?
one other thing - the rubber gasket that comes with the pump head creates the seal between head and body, plus i'll use some silicone grease around the gasket to help it - shoulds that be enough as don't wanto to have to drain down again after replacing pump!!!!!?!!
thanks - will get on with it when it arrives :)
oh one other thing i noticed/read on here - will a vacuum be held when i drain down so i only drain down some of the system water? or will it likely not as there's 2 open ends on the pump?
Just drain to below the level of the pump.
You will then be able to work at your liesure without worrying.
yeah boilers upstairs so will drain down half (and add half inhibitor)...
gotta make sure i DO drain down under pump though ........ !!!!!
drain until your upstairsa rads no longer release water when bled!! (if they are higher than your pump)!!
