Worcester RF546 Digistat battery clip broken - replacement needed?
18 Jan 2020
Hi there - hoping someone can help...
I have a Worcester RF546 Digistat (for my Worcester Bosch Greenstar 37cdi) which fell of the wall and the battery clip that stores the batteries had a small accident. The plastic that holds the batteries and keeps it in place is cracked and I have had to tape it up to keep batteries from falling out, but it all works fine.
If anyone has a faulty digistat with the battery clip in place that they can sell, that would be great... (crosses his fingers as he types)
If not possible, I assume I can just buy a replacement digistat from Drayton which looks exactly the same?
https://www.draytoncontrols.co.uk/p...t-rf?redirected-from=DigistatRFRoomThermostat
Will my boiler thermostat just pick up this new digistat or is there any other config needed?
I'm not sure of the thermostat model from Worcester, but it looks exactly like this.
https://www.draytoncontrols.co.uk/p...ip-in-controls-programmable/lp20rf-digistatrf
Thanks in advance
It would need pairing up whether a Worcester or Drayton. They’re usually paired in the factory, so you would need to do this manually, assuming it’s the same model.
