Hi All first post here.
We have a Worcestor 350 Boiler the one with two pumps. Recently it was cutting out when running hot water too long the button on top (lockout reset button) had to be reset to enable it again, so we had the thermostat replaced along with the Expansion vessel and the pressure relief valve. Everything worked well for a couple of weeks then the relay RL1 started buzzing and we we had to replace the pcb once that was replaced the other pcb developed a fault immediately so we replaced that too.
Now the system starts and ignites but if we don't run hot water it sounds like its boiling dry?? (sounds like a kettle with no water in it) and trips the lockout reset button.
What I need is some advice as to what I should be looking at as I don't want to call out the boiler man again as he charged me nearly £50n just to agree with what I thought initially
