worester 240 combi bf
11 Nov 2007
Hampshire
please help my boiler is cutting out after ashort while of heating on or i run a bath , i have to reignite the boiler it will run again then cut out. the overheat stat is doing its bit ,shutting the boiler down and gas valve, but i stuck on what is not working to control temp.............thanks
Pump, sensor, blockage in boiler, lack of pump over run.
One of several things.
Easy for a competent engineer to diagnose in front of boiler.
hi there , the pump is running after boiler shuts down which sensor do you think it would be
Well in that case it elininates just one posibility, leaving:-
Pump, sensor or blockage in boiler!
