Would the wall fall down ?
26 Feb 2011
Durham
hi,
The rear elevation of my two storey house has a 6 foot patio door and a 5 feet window separated by 6 feet of brick/block work. (there are two windows on the upper floor)
I would like to replace the 5 foot window with a patio door but am nervous that the removal of the bricks under the window would weaken what would become a central pillar.
Could members please tell me if this work is feasible without altering the structural strength of the rear wall.
thanks
john
In theory, if you are only removing the wall below the window then it shouldn't be load bearing as the lintel over the window should be carrying the weight above.
If you are removing anything above or to the sides of the window to accommodate the new doors, then it could cause structural weakness.
Assuming you mean the 6ft wall will be the central pillar, then this may have to be strengthened. It's always best to consult a structural engineer with this type of work if you are in any doubt whatsoever.
as long as you don't disturb the bearings of the lintel you'll be fine, use a petrol/electric cutterfor neatness. remember to use a dpc when you close the cavity
hi,
many thanks for your replies.
I thought I may be ok but I didn't know whether the window bricks somehow contributed to the strength of the middle section of wall.
I will try to remove the bricks as carefully as possible using a cutter, not a chisel.
cheers
john
