- Joined
- 2 Dec 2004
- Messages
- 738
- Reaction score
- 8
- Country
Been doing some more work on the exterior of my house. Ive had areas of water damaged brickwork replaced, stripped horrible thick paint from large sections of wall, had a section of wall professionally repointed, and Ive repointed a section of a wall myself too.
Im now lifting pretty old worn out slabs on my patio near to the house. They are bedded on 20-40mm sharp sand which is on top of an old concrete slab as you can see in the pictures.
Also there is an area of render around the french doors which goes all the way to the ground, bridging the DPC. This is painted with the same horrible thick latexy paint as the wall was, and areas are clearly flaking off due to damp. However the render itself does not appear to be falling off the wall.
So do you think I should break off this render? Ideally I don't want it rendered but the bricks under may be in a state.
And for the patio, do you think its ok to lay a new patio on top of this old concrete slab? The only issue I'll have will be the levels and slope, as the patio appears to slope quite alot more than is required and slopes away from the house and away from the outbuilding to the right.
Here's a before picture before I started any of the work:
Here's the paint stripped and repaired/repointed walls:
Here's the rendered section and concrete slab underneath the slabs/sand bedding layer:
