Converted an old system to a fully pumped vented system.
Called back today and discovered the vent pumping boiling water over and the condensation in the loft space was un believable.
It does need a lid on the tank however it shouldnt be pumping over red hot like this. WHAT HAVE I MISSED?
Boiler is downstairs with Flow running up to loft space, through air separator which also has Vent attached, into pump then through Mid position valve back to heating / hot water.
The Feed is tied into the heating circs close to air separator.
pump is set to speed 2. Valve on return from cylinder is approx half closed.
There is a auto bypass before the pump attaching to the return pipe.
Any suggestions would be lovely, never had this issue before, wondering if i should remove air seperator and pipe without.
Neil
Neil
