Yale 6400 PIR sensor issue - no delay set in ENTRY TIME
24 May 2013
All system is set to factory settings. For some reason movement detected by PIR causing alarm without 20 second delay. What I made wrong?
Do not have magnetic contacts and do not want to use it.
You need to set a device as an entry device. If its going to be a pir then you have to change its settings..
Go to the menu via . . . PR . . .code . . ..tick
Then choose the 'device' menu underneath walk test.
scroll down to 'edit device' and press tick.
You will now see a list of your enrolled devices.
put the cursor next to the one which is going to be your entry sensor
Now press tick and change the first attribute to 'Entry' (It will currently be set to 'burglar' press tick again and again and again until you see the list of devices again.
Now backspace out of the menu till it says Alarm Off.
WOW, it was easy!
Thanks a lot!!!
I download this instruction: http://www.yale.co.uk/Yale/Yale_co_uk/Product Instructions/Yale Kit 4-2010.pdf
and didn't spent a lot of time on reading it carefully. Site 17:
Zone Type List
Burglar
• When the system is in home or away armed mode and a burglar device is triggered, a burglar alarm will be activated immediately.
• A device set to burglar will not trigger an alarm during entry or exit delay periods.
ehhhh... stupid me... next time I will be search not only google :)
