Hi All,
I'd really appreciate some help on an issue I'm currently having.
I have purchased and installed the Yale HSA 6400 system, however I keep getting the amber fault/warning light (tamper) on the control panel for the DC I have placed on the kitchen door located at the rear of my property.
I have tried to clear the log but it still remains. It will not delete when I hit the return key and select to delete/clear the fault.
I have however managed to clear this fault by removing it from the control panel and then adding it again as a new device. The problem I am having is that every time the back door is opened, there is a fault and it will trigger the amber light again!
I only wanted the DC on the rear door so that when the alarm is set, if an intruder entered via the rear door it would trigger the alarm. I have tried to change the settings for the DC as Exit, Away, Burglar etc, but every time the door is opened the fault will appear on the control panel until the device is manually removed from it and re-added as a new device.
We open the kitchen door on a regular basis to go to the shed, when we cook every night, use the garden etc..so it's really annoying.
What am I doing wrong?
Thanks in advance!
Thanks in advance!
