yale Premium Alarm Kit Remote access problem
10 Feb 2017
Turkey
Hello,
I have Yale Premium alarm. I connected ericksson FCT for remote access insteady of pstn.
When alarm triggered, system calls me and i can disable this alarm with my mobile phone.
But i cannot enable alarm with using my mobile phone.
when i enter my ping code within 3 seconds, i never hear a long beep. Then system close the phone.
I cannot understand what is the problem?
This is the procedure for enable alarm kit with using phone:
Remote Access
The control unit allows you to control your system
remotely through the telephone line.
1 Dial the phone number associated with the Control
panel.
2 Hang up on the first ring.
3 Wait 5-10 seconds.
4 Dial the number again.
5 The control unit will answer the phone on the first
ring of that second call.
6 Enter your PIN Code within 3 seconds.
7 If the PIN code is correct, you will hear a long
beep. A list of different functions is detailed below:
Press 2 Put the system into away armed mode (arm
the system).
Press 3 Disarm the system.
Press 5 Checking the system status. Long single
beep for Away Armed, two beeps for Disarmed and
three beeps for Home Armed.
Press 7 Siren on.
Press 8 Siren off.
Press 9 or 0 Disconnect.
Daft question but why when the alarm is triggered would you want to disable it? Robber breaks in, alarm goes off and you disable the system remotely. Am I missing something here?
Hello,
We have a cat, so sometimes alarm can be triggered because of cat. But my main problem is not that actually. :)
Alarm panel connected fct (gsm module) so alarm can call my phone if there is a emergency situation. I haevnt CCTV. But main problem is i cannot enable alarm with using my phone.
