Yellow water mark stains
14 May 2013
Hampshire
Had a leak on a chimney breast wall from the chimney. I sprayed Stain Block and re-painted white emulsion but it still shows how can I cover I? Thanks for any suggestions
Two coats of each. Covered some of it but I can still see the yellow. Wall is dry as well
you could give another couple of stain block a go (if you still have some left) if that fails then just put on a coat of oil based undercoat on.
