yet another leaking washingmachine
10 Feb 2007
Kent
Hi all
I have a Zanussi 1261 washer dryer that has developed a small leak.
We have checked the door seals and that is fine.
the leak appears to come from (looking at the front of the machine) the left hand side half way to the back.
I have checked the inlet pipe- that is nice and tight with no sighn of a leak.
the outlet pipe seems to be ok as well.
As the machineis hard wired in to a tiny utility room i wondered if you good people had any advice before I removed half the appliances in the room just to check further
many thanks
only thing you can do is remove the lid and use a torch down the left side to see were leak is
Now why didnt I think of that!!!
on reading it seems the main culprits are
door seal
soap dispenser
pipe connections
pump
so a bit of investigating I think
thanks for the help
