To be honest I am not 100% sure as I have never really delved into it to deeply, but I believe that the basic difference is the Rupture Capacity of the Fuse. BS88's are HRC (High Rupture Capacity) Fuses, whereas BS1362's are not. This is to do with the amount of current that can be drawn through the fuse for an initial period before it will blow, similar to the Type ratings for MCB's. The 1362's would be a Type B, but a BS88 would be a Type D, if you see my point. But there could be other technical differences as well that are buried in the wording of the British Standard that relates to the particular type.
when i was taught at college BS88 was a sealed fuse in a substance such as sand(probably special type but can't remember after so long) and so able to withstand a much higher breaking capacity without the capsule exploding, whereas the BS1362 fuse was merely wire encapsulated within a capsule/ cylinder try breaking one open and you'll see no filler inside these fuses we were told were no better spec than a rewireable fuse and to be treated as such the endcaps are merely pushed on rather than properly sealed like BS88, in other words they deteriorate in a reletively short period and cannot be relied upon to take their rated current specifications after a time period whereas BS88 is not so susceptible to deterioration.
Thanks Kendor, that makes sense and does ring a bell. I'm sure I was told that at college, but one of those things you tend to forget when you don't think about it all the time.
The sand in question your thinking of is Silica Sand.
